JWDryHeat's avatar
JWDryHeat
B&W Companion Hitch Shock replacement
Just called B&W and they are sending me a new shock for my RVB3300 hitch. Wow. No money required, will be here on a couple days. Now, how do I replace it? Has anyone done this? Does it require taking the whole upper end apart?
  • laknox wrote:
    ford truck guy wrote:
    Jerry, really?? You want Ron to report you to the B&W club??
    Did you know there is 1 single grease zerk as well?
    There =should= be 3. Should be a 90 zerk to grease the head pivots so you can grease without having to take the head off to do so. Been wanting to drill and tap these for years, but have never gotten roundtuit. :-)
    Lyle
    Here ya go. :)
    Lyle
    I only have 1... The bushings are accessible once the head is removed...
    HITCH MAINTENANCE
    Grease the saddle through the grease zerk
    approximately every six months with multipurpose grease. This allows the coupler to
    pivot freely.
    As needed, grease the polyurethane bushings
    with high-grade lithium grease.
    Spread a thin layer of multi-purpose grease around the
    inside surface of the jaws where they grasp the kingpin.
    On page #24 is the maintenance - B & W maintenance - Companion Ford Puck
  • B&W answered this question with the instructions that came with the shock. Now I need to get a 1 1/2 inch wrench times two.
    Lyle
    Here ya go. :)
    Well, cr@p. Now I =do= have a round tuit, so I'm going to have to do this. Fortunately, we have POWER at our shop! :-)
    Lyle
    Lyle
    HITCH MAINTENANCE
    pivot freely.
    Yes, I do do this, yearly. (I don't tow all that much, right now.) Jaws get greased every couple trips.
    Lyle
  • its an easy job, i did mine last summer in about an hour or so. B&W was nice enough to send me a free replacement shock for the head.
