I have a Companion from B&W, purchased back in 2012. Is it just me, or does anyone else with this hitch, have to replace the U-bolts/hardware and/or the draw down bolt/aluminum block? I have to replac...
I've pulled my Companion out a few times and never had any issues with the bolts/nuts galling up. Stainless nuts/bolts do tend to gall up if not lubricated. Next time you take it apart, before you put it back together use some anti-seize on the U-bolts. Be sure to lower the torque settings about 10-15%.
