I have a Companion from B&W, purchased back in 2012. Is it just me, or does anyone else with this hitch, have to replace the U-bolts/hardware and/or the draw down bolt/aluminum block? I have to replac...
I've had my Companion hitch since 2015. Twice a year I crawl under the truck and soak the block, spring & rod with lithium grease. Also spray the moving parts of the jaw. Then 4-5 pumps of grease into the grease fitting under the head. I have noticed that the paint has flaked off of the turnover ball frame under the truck but minimal rust, so I spray it with a rust inhibitor.
That is all that I ever do and have never had an issue.
