laknox wrote:
rtreptow7 wrote:
Just an update. Brought the door in the house last weekend. Was going to go borrow some pipe clamps from my father in law. Grabbed the door to show him and the floating panel now seemed loose and I could easily squeeze the frame back together by hand. Last weekend I couldn't get it to come together no matter how hard I pushed on it. The door did sit in my wood furnace room over the past week. It gets pretty warm and dry in there. So I'm guessing the humidity evaporated out of the wood? Will try to glue and clamp it back together and see what happens when it returns to the elements.
As one of the others said, you may want to disassemble the door and sand the center panel a bit, to give it a bit more space to "float".
Lyle
I'd like to try and dissassemble but the thing is nailed or stapled together with tiny little nails or pins too. Not sure how to get those out without ruining the door finish. I'm wondering if the glue will be strong enough to hold the door frame together? I can see how the expansion ripped the pins right through the wood.
