I have the cable operated dump valves also. I had a failure of the black water valve when 2000 miles from home. Took it into a dealer and they said it was the valve that was bad & would have to be replaced but it would take 10 days for the valves to arrive at their location.We would be half way home by that time. I had an end of line valve on the sewer dump line so I used that until I got home. Took it into my dealer and they replaced the cables to the black water and one gray water valve. Works much better. Oh yes, while out west I ended up trying to get a look at the cable, so I took the handle off and proceeded to pull on the cable. There had to be 2 miles of cable in there. Why? Who knows, but my dealer shortened the new one. They said it was the inner sheath that was damaged therefore making it hard to pull and push and eventually failed altogether.
