AirSupport
Dec 13, 2019Explorer
Cummins12V98 wrote:
"Dodge 3500 4x4 crew cab dually that has a GVWR of 14,000lbs"
No such thing!
I found that number on the Dodge truck website after clicking “build your truck.” I put all the options I wanted on it as far as engine, bed length rear axle (dually), factory installed rear axle air bags and driveline. It clearly came up with “GVWR 14,000.” I was shocked too but that’s what comes up. Correct me if I’m wrong, it that number is what the truck is capable of hauling, not its actual weight off the dealer’s lot, right???
Maybe I’m reading it wrong, but I’ve done it several times and it’s always the same.
Never the less and from what I understand, DMV goes by GVWR (what it’s capable of hauling) and not what it’s actual weight is, when setting limitations on vehicles.
I just wondered if my GVWR COMBINED with truck and fiver and exceeded 26,000lbs, would I then need maybe some other life fe class or endorsement.
Thanks again all. I’ve learned a lot from some experts here on this thread.
About Fifth Wheel Group
