Petethescot's avatar
Petethescot
Cameo slide out
Cameo slide out issue
Hi All I have a 2008 Cameo F35Sb3 and today one of my slide-outs would not function properly when trying to bring it in. It would move 6 inches then stop I would wait 10 sec and it would again move about 6 inches, after about three moves like this it comes all way in. tried this several times and same results. BTW goes out with no issues. So here are a couple of questions: Is this a bad power connection or is the slide-out motor starting to go. Where would the motor be on a Cameo underneath it is all sealed down there so cannot see.? it is the doorside slide out Would you access it from underneath or inside under the dinning and seating area? thanks for any reponses. cheers Peter
  • It is easier for the slide to go out, than to bring it in. My thought, thing to check, is the circuit breaker, which often has auto reset. It would act like you mention, when under load. These breakers weaken over time, and yours may need to be replaced. It should be close to the battery, likely just inside the basement on the wall.
    Jerry
