Iraqvet05
Apr 25, 2019Explorer
valhalla360 wrote:Iraqvet05 wrote:
The compression ratios of modern engines would make it impossible to turn a car over by hand.
Actually, compression ratios haven't changed much at all in decades for gas engines.
Something like 8-1 is typical. High performance will get up around 9-1.
They can't go too much higher or they will start to knock and compression ignite (diesel operation), so you can hand crank a modern 4 cylinder roughly as easily as an old model T (of course assuming they provided a crank and a place to fit it)
8:1-9:1 is common for a modern engine but the Model A and T (when hand cranks were common) had a compression ration of 4.5:1.
I got to drive a 1930's Allis Chalmers WC tractor in a parade once (wife's grandfathers) and it about killed me trying to get it started by crank. Those guys had to be tough to own a car or tractor back then.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
