- Old-BiscuitExplorer IIIIs your 5th wheel a 50A Service?
Are you plugged into 50A receptacle OR using a 50A/30A adapter?
Either way....
Sounds like 1/2 of your AC Power Dist Panel is NOT hot
Bad connection on one leg of power cord....either OEM or adapter - CA_TravelerExplorer IIISounds like your GFCI circuit connected to the inverter and the rest of the rig is not connected to shore power for some other reason.
- RollnhomeExplorerCheck breakers on inverter. What type of rig do you have? 30-50 amp etc
- Tex250ExplorerAll breakers are on and not tripped. Hot water heater is on its own breaker and not working.
AC works and all GFI outlets inside and out work - Johno02ExplorerCheck you circuit breaker panel.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
