BB_TX
Mar 01, 2017Nomad
Being a 50 amp rig it is likely the wiring is there. But no way to know for sure without searching for the wiring. Is there a rectangular cover plate, like an electrical cover plate, in the ceiling near the vent opening? If so, pull that cover and see what wiring is behind it. Likely you will find the typical 3 wires (hot, neutral, ground) for the A/C connection. Then you would have to locate the other end of those wires in the electrical distribution center (breaker panel).
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
