RedSunshine's avatar
RedSunshine
Carlisle RH Trail vs Maxxis M8008 Tires GVWR 10k
We want to replace the OEM tires (225/75/15 "D" load range) on our 2012 Keystone Laredo 275SBH fifth wheel. It's sticker empty weight is 7199, GVWR is 10k. We've never weighed it all stocked up, but I'd guess we're around 8500 lbs.
We only haul shorter distances - 100 miles one way is typically the farthest we go however, we do have a 200 mile trip planned in a few weeks. For that, we don't plan to haul loaded with water. We live in Wisconsin, travel in Wisconsin, so we don't need to consider hauling through Death Valley for heat issues. We put on less than 1,000 miles/year. She's stored outside in the summer (May - Oct), inside in the winter.
I read here that Carlisle makes a crappy tire, but it appears some are USA made, some are not. Their Trail RH tire was "redesigned" in 2011 so perhaps that tire is okay now. The local tire shop classifies both it and the Maxxis as their "BEST" quality tires.
Questions
1) Is load range D sufficient for our use?
2) Is it really worth another $100 in cost to get the Maxxis M8008 over the Carlisle RH? If so WHY?
Thanks in advance...
