MontanaNewbie's avatar
Sep 12, 2013
Cart before the Horse? Just got 1st 5er... Need truck wisdom
Hello Woodall Wisdom!
I have just put in a bid for a 2008 Montana 37' fifth wheel. I'm so new to the game I don't even have the vernacular down, so pease excuse my ignorance. I am headed out this weekend to get my TV (tow vehicle, right?) I have read on this forum about doing my research on the tow capacity. I believe I need a 1 ton to tow this since I have read 2 different weights for it, 1200 and 9450, I'm going with the larger # to be safe. I'm unclear about height issues. Do I need to be sure my 5er and my TV match in ground clearance? Also, I understand that if I get an 8' bed I can use a standard hitch, and if I get a 6' bed I will need a slide hitch. Is this accurate? If so I would love any wisdom on which would be best. I have an 18 month old who is in a carseat and have been reading about safety in a 4 door truck (quad cab). Again, I'd appreciate your wisdom! Here goes!
Anna
  • It appears to me that you have a hitch weight (1200) and a trailer GVWR (9450). With those weights, any 1 ton (SRW or DRW) would tow that rig just fine. A question to ask of yourself is if your tow vehicle will be used exclusively for towing? or will it be used as a daily commuter? My truck is a daily driver so I bought a 2013 RAM 3500 Crew cab 6.5' bed SRW. Now I'm guessing you bought a Montana 3400RL as that's the quickest 5th wheel Montana I can find in the size range you specified. It appears that it has a scalloped front end so that a slider wouldn't totally be necessary except in the most extreme of turns with a short bed. Many members here like the idea of a slider to be on the safe side in case they do need to execute those extreme turns. As for clearances over the bed rail, you want to aim for 6" of space between your bed rail and the 5th wheel. That's basically the clearance between the floor above the kingpin and the top of your rear bed rail. You'll want to measure this height with the 5th wheel level and try to get a truck which has its bed rails at least 3 or 4" below the floor *BEFORE* they're hooked together. The truck will probably squat a little bit once you hook up the 5th wheel to it.
  • Here are the specs to two 2008 Montana's around 37"
    3295RK
    10960
    3365
    2325
    36' 9
    12' 9
    64
    38
    76
    60
    235/80R16E
    Fifth Wheels
    All
    And
    3475RL
    11040
    4440
    1980
    37' 9
    12' 9
    66
    55
    100
    60
    235/80R16E
    Fifth Wheels
    All
    Not sure what you bought. But here is the 2008 spec page. http://www.keystonerv.com/previous-years?brand=Montana&year=2008
    Just about all of them call for at least a SRW 350/3500. Add the shipping weight and CC to get the GVWR. Chris
  • All I know is:
    We tow a 10300 pound (dry) fiver.
    I think anything less than the RAM 3500 DRW we tow with would feel weak with the GVW we have on average.
    Bottom line:
    Glad we own and operate a 3500 DRW (wish it was an automatic trans for more capacity)
