wantabe351
Jun 29, 2016Explorer
OMG, yes I did have separation on my 05 5th wheel, 34RLTS..We traveled about 15,000 miles with it going cross country and local travel too. Then on one of our vacations coming back home we had a layover and on setting up the camper to to use I noticed we pulling out the 2 recliners and 2" plus gap along the back wall and floor. This just freaked me out, When cking it out outside the back wall had separated from the floor and left side wall...starting from the floor and going up to about 2/3rds the way up the wall...I was wondering if I would make it home or would it just fall apart on the NY through way...I made it home to repair it must self..I found the screws from the floor frame pulled out from the wall frame, I removed the screws and other attaching hardware on the RV where the separation had happened, the made a ram using a 4x4 and plywood,placing the plywood against the back wall and the 4x4 against a big strong oak tree we had, with the truck and camper attached together..I put the truck into revers which pushed the back into place..But before that I used a glue along the floor frame, once contact was made I bolted the 2 together and never had a issue of separation again...I had a few problems with my CedarCreek but do miss it, when I traded it in I had approx 65,000 mile on the 5er.
About Fifth Wheel Group
