time2roll
Oct 25, 2020Nomad
DReisinger wrote:Assuming all is working as designed just connect and drive.
What do I need to do to be able to charge my house battery from the TV generator while traveling during the day
If you want to verify all is working get out your voltmeter and observe if the trailer battery voltage rises as you plug the connector into the running truck.
Charging is fairly slow. If you are really relying on getting a full charge while you drive 4 to 6+ hours consider a DC-DC charger to get the right voltage on the trailer battery.
https://www.renogy.com/12v-dc-to-dc-on-board-battery-charger/
Best to get the 20 amp.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
