enblethen
Oct 31, 2016Nomad
There should be a converter case ground.
Then there is a 12 volt negative that goes to the 12 volt system.
Don't get them confused.
I go along with a circuit breaker at the battery(ies) or in the 12 volt DC panel.
Another thing to do is go through all the 12 volts connections. Make sure they are clean, have electrical grease on any tinned copper or aluminum connectors and buss bars, and insure they are tight.
About Fifth Wheel Group
