DanNJanice
Oct 31, 2016Explorer
Just so I understand correctly.
You were running on 12V and everything was working normally. Then suddenly no power...correct?
When you plug in and the convertor takes over, everything works OK...correct?
Sounds like an open between the convertor and the 12Vdc battery. Check all connections, fuses, battery cutoff switches, also find the self resetting breaker(I have seen these fail in just the way you describe).
About Fifth Wheel Group
