SCVJeff
Nov 01, 2016Explorer
DanNJanice wrote:cept he's implying that playing with a ground seemed to make things better?
Just so I understand correctly.
You were running on 12V and everything was working normally. Then suddenly no power...correct?
When you plug in and the convertor takes over, everything works OK...correct?
Sounds like an open between the convertor and the 12Vdc battery. Check all connections, fuses, battery cutoff switches, also find the self resetting breaker(I have seen these fail in just the way you describe).
It's meter time!
About Fifth Wheel Group
