BigDogF250
Nov 01, 2016Explorer
Yes, the converter has it's own chassis ground to the frame. It also has two white wires, one connects to the frame and the other connects to the ground bar for the rest of the trailer. Adding a direct ground from the frame to the ground bar made things work for a full day, then it happened again.
Thanks for the input, reinforcing my thoughts that it has to be between the batteries and the electrical panel. That run is about 20 feet with the way WW ran the wiring, mine will be about half that.
About Fifth Wheel Group
