BigDogF250
Nov 01, 2016Explorer
I checked the ground at the battery (and cleaned it) but need to chase to frame to check there.
The is no circuit breaker at the battery, it's using fuses. I pulled, cleaned, and adjusted tension on them to make sure there is good contact. Planning to replace with a breaker style because I hate having to maintain the fuses (clean and reset).
About Fifth Wheel Group
