BigDogF250
Nov 02, 2016Explorer
2btowed wrote:
use meter and check both sides of disconnect switch,move it around and make sure it does not disconnect on its own.Mine did,when replacing it fell apart in my hands...quality.went back with marine grade rotater,works great.
Thanks for the reminder to order that. I did check the one in there, and actually swapped to a spare, but I'm moving to a marine rated one because it's built for the cable sizes I am running. The 75 amp push/pull on the trailer uses a pretty small and somewhat flimsy screw into tab design that I don't like.
About Fifth Wheel Group
