nayther
Nov 02, 2016Explorer
BigDogF250 wrote:
Nayther, you made me almost laugh coffee out my nose. It's a WW built in 2005, the "common bus" is wire nuts! One more thing I found wrapped in electrical tape this weekend that needs to be replaced.
At this point I am starting with running proper grounds and new positive from the battery to a real common bus, replacing the funky 8 fuse and rigged 3 fuse add on they used instead of a proper fuse panel and seeing where that gets me. Hopefully it's just corrosion or gremlins in one of those systems.
"bus" was a relative term, you got my intent.
I'm like you though, might as well tear it up and do it right at this point.
About Fifth Wheel Group
