goducks10
May 09, 2019Explorer
Super_Dave wrote:
Goal would be to evaluate whether pin weight put truck in rear end squat below level from empty, ass high position. I don't think that involves fender well clearances unless I'm not understanding how that pertains to truck being level when loaded.
I assume that the fender wells are the same off the ground when the trucks level. I thought all MFG built them that way. What else would you use to check level? Mine's 3" higher in the rear using the fender well when empty.
Using fender measurements takes the guess work out. Don't have to be on level ground.
About Fifth Wheel Group
