rynophiliac's avatar
rynophiliac
Chest Freezer in the garage
Does anyone know how many appliances can run in the garage safely without it cutting the circuit breaker? I've got a chest freezer in the garage now and it has been working perfectly but I'm consider adding a small 4.5 CU FT mini fridge plus a water cooler in the garage as well. Iv'e got 4 sockets in the garage but they are all hooked into one breaker panel. I don't wanna pop the circuit and loose my meat in the chest freezer.
  • Definitely invest in the freezer alarm. I found out the hard way and lost half a freezer of meat a few years back. Alarms are cheap and work well.
  • Naio's avatar
    Naio
    Explorer II
    Yeah, an alarm is the way to go, if you plug them all in and the breaker doesn't trip immediately.
    After all, I would THINK it would be rare that they would all start simultaneously. Driveway test them, together, for a few days and return your new purchase if it turns out to be incompatible with the others.
    One thing to consider: Having all these appliances will heat up your rig quite a lot. Depending on where/when you camp, this can be a good thing or a bad thing. I sure appreciated the heat my one freezer gives off this fall. But in summer...
  • If you have a 15 or 20 amp breaker then the amperage at peak (usually start up) of the devices can't exceed that. Some where on each device should list the AMP draw. I looked online and couldn't find an example for a chest freezer for you though.
    I'd also get a power outage alarm, you can find several on amazon.
