B.O. Plenty wrote:
Cummins12V98 wrote:
^^^^^ Shocks will do wonders. What air pressure and what weight on rear axle?
Rear tires are at 65 psi, no idea about weight, haven't been over a scale yet. Thank you for your reply.
B.O.
65psi is for full axle weight rating of 9,750#. Really doubt you are anywhere that. My RV weighs 23k, I run 65 at full axle weight rating. Since you are using a 18k hitch I gurantee your load is much less than RAWR.
Weigh your setup and use weight/inflation chart and add 5 psi to what is called for. I am betting you will drop 10-15psi. It ALL makes a difference.
