rhagfo wrote:
larry barnhart wrote:
Wild Card wrote:
All you have done is isolated the bad ride of your camper from the truck. I would make the suspension better on your rv so it doesnt get torn apart bybthe bounce and vibrations
I am sorry to say I was thinking the same.
chevman
X3
A cushioned pin box should be the last step to correct "Chucking". Not mentioned by the OP was if the 5er has shocks, if your 5er doesn't ride as smooth as the TV I am sure you will feel it. I chose to fix the ride of the 5er rather than masking it. Our 5er chucked when we first got it ,the biggest improvement came with install of shocks!
No it doesn't have shocks. Shocks might have a impact on vertical (up and down movement) but I don't see how it would have much effect on lateral, front and rear movement anyway.
