2oldman's avatar
2oldman
Explorer II
Jan 30, 2017
City water filling fresh tank
Arg!! This is a new problem. Why is my tank being filled (slowly) by the city hookup?
I find water stains (big ones) on the underside of the coach, under the water tank.
  • Internal check valve in on-board pump leaking allowing backflow thru pum
    OR
    If you have a water panel with 'FILL' position it is leaking thru allowing water to go to fresh water tank
    No 'FILL' valve then pump check valve
    Run pump and let the flow thru pump clear check valve diaphragm of debris/scale....hopefully.
    I never use city water directly any more......
    Fill tank and always use pump.
    Had a fitting break while on city water flooded rv $6000 damage.
