B_O__Plenty
Sep 05, 2013Explorer II
mpfireman wrote:Pure BALONEY! Obviously you have never compared a ST tire and a LT tire side by side. The sidewalls on an ST tire are like a bicycle tire in comparison. The only reason they are on there when new is because they are CHEAP and the manufacturers don't want you to know that...Stop drinking the Kool Aide! If you ever ran a set of LT tires on your rig you would never go back.
ST tires are made with stiffer and additional plies in the side walls, thus when turning ,your trailer's 2nd or 3rd axle being stationary causes these other tires to slide around corners. LT tires lack these added plies. But again many RV owners have switched from the ST tires to the LT tires. It's your rig, so you have to make that choice. ST tires also contain additional rubber compounds that are designed to withstand long exposure to the sun, thus they say, less sidewall cracking.
B.O.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
