- shadows4Nomad
krinkle wrote:
Coachman Chapparel. You have our sympathy..from a former Chapparel owner
Sorry for your troubles. I have been quite happy with our Chaparral. What kind of troubles did you have? - krinkleExplorerCoachman Chapparel. You have our sympathy..from a former Chapparel owner
- dlowr31733Exploreri guess i should have started checking the simple stuff first. a new battery and we are back in business!
- xPIXxExplorereverything will run through the battery cut off switch except the AC and Micro. Do those two work?
- bstarkExplorerIf you're plugged into a live 115V service and all your breakers and main is active then cannot explain why you wouldn't be getting some feed to outlets and microwave etc,.
12volt stuff on the other hand may be explained by a resettable breaker, like one of the old car leadlight breakers from the past, in your battery cabinet near the positive feed wire fastened to the side of the cabinet somewhere. If equipped it should have a small black button in it's center that needs to be pushed in. - newman_fulltimeExplorer IIis your microwave on
- dlowr31733Explorerdo not have a generator, does not seem there is any power to unit, even lights that work off 12v system when not plugged in to shore power do not work
- newman_fulltimeExplorer IIdo you have power to the breaker?
do you have a generator - dlowr31733Explorerbreakers all in order.
- newman_fulltimeExplorer IIdid you reset the breakers
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
