Dick_B
Oct 20, 2015Explorer
If you have a pad you should put something between the tire and the concrete eg. plywood. A gravel `pad' doesn't crack and can be refreshed with a new load of gravel at any time. I think the gravel to use is Grade 8 limestone.
Do NOT use the pretty little round pellets the a pad. The gravel needs to `lock' against each other to form a firm base. The little pellets just move around which makes it more difficult for a wheel to go thru it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
