JIMNLIN
Jul 20, 2018Explorer III
Newer gen Ram 2500 can have a 6000...6200....6500 RAWR and is good for around 3000-3400 lb payload in the bed depending on which RAWR package.
The truck won't have any issues towing that size 5th wheel trailer.
We have another member (IB516) that had a newer gen 2500 RAM 6.4 gasser and pulled a 13k ? gvwr 5th wheel trailer just fine. He may be along to give you his opinion.
I have a older '03 2500 Dodge/Cummins and have pulled a 11200 lb 5er since the truck was new with no problems. Its not close to being maxed at anything other than 310k miles on the odo. The 3/4 ton Dodge/Rams have no upper over load spring pack like the older 2500 truck did. I later added Supersprings mainly because anything over 1500 lbs in the bed and the rear suspension sags.
I also pull a 16k triaxle GN stock trailer and other assorted GN/bumper pull trailers.
I wouldn't add anything to the trucks suspension till you get it loaded ....then is the time for that decision.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
