Dougie123
Jul 20, 2018Explorer
JIMNLIN wrote:
Newer gen Ram 2500 can have a 6000...6200....6500 RAWR and is good for around 3000-3400 lb payload in the bed depending on which RAWR package.
The truck won't have any issues towing that size 5th wheel trailer.
We have another member (IB516) that had a newer gen 2500 RAM 6.4 gasser and pulled a 13k ? gvwr 5th wheel trailer just fine. He may be along to give you his opinion.
I have a older '03 2500 Dodge/Cummins and have pulled a 11200 lb 5er since the truck was new with no problems. Its not close to being maxed at anything other than 310k miles on the odo. The 3/4 ton Dodge/Rams have no upper over load spring pack like the older 2500 truck did. I later added Supersprings mainly because anything over 1500 lbs in the bed and the rear suspension sags.
I also pull a 16k triaxle GN stock trailer and other assorted GN/bumper pull trailers.
I wouldn't add anything to the trucks suspension till you get it loaded ....then is the time for that decision.
Thanks! Rear Axle WR is 6000 on my truck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
