donn0128
Mar 09, 2018Explorer II
Sorry Dave. Air bags will not make the ride worse. Unless that is the owner leaves the bags fully inflated. Thats the beauty of air bags, the owner can adjust the air pressure according to the load being carried. No load, 5PSI is more than enough.
To the OP. BT,DT, bags, tires and the truck still did not comfortably handle my load. Before you spend any more money on band aids I suggest you take your loaded ready to travel rig across a set of scales. That should help you make the correct decisions.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
