NC_Hauler
Dec 30, 2014Explorer
ricatic wrote:
To all
This is why I posted the question. This site has knowledge beyong compare. I was aware of the quality and reputation of the "Ribs" and the Duravis 250. I would consider them despite their significant additional cost.I did nit know about the 500...
Here is my thinking though...I had no issues with the China Bombs on my Big Horn in 30,000 miles. Was I just lucky? I tow at 65 mph and keep the tires properly inflated. I try to stay off the cubs as well. I only plan on running this trailer 2 more years...or so... then move to a newer and larger trailer that will likely have 17.5 G rated tires...will my criteria make spending the additional money for R250's and steel carcass unnecessary performance overkill?
The R500's are only $30 a tire more than the Coopers. Jimlin certainly makes buying the Coopers less stressful given his success with them to date...but $120 is not going to make or break the decision...
Thanks for the help...keep it coming...I am learning a bunch...
Regards
Nothing happened with your China made tires running 65 mph for 30,000 miles of towing...That speaks volumes for the tires you had on your 5er...Heck, I'd save as much as possible and go back with cheapest you can get or the one's you had on it to begin with..If you're only going to keep the unit for a couple more years....I see no reason to get rid of what worked for you....JIMNLIN stated the Coopers were good and came recommended. If that's the cheapest you can go and still get a good tire, that's what I'd do...
Don't understand the post though because you had very, very good experience with OEM tires, and if it ain't broke, don't fix it....I'd just purchased same tires as OEM or went with whatever your tire dealer recommended seeing as how you're not planning on keeping the unit.....
About Fifth Wheel Group
