Veebyes wrote:
AZ T&T, you can be helpful. The description of the kit is not very clear. I assume for the price the hardware is supplied for all 6 springhanger points, correct?
Figuring out what to do does not seem difficult. Make sure the fron axle is as it should be first by dropping a plumb from the kingpin & measuring any differences each side, same point, on axle or U bolt. Then do the same for rear axle.
Going to take time but my DW is a well trained boatwoman so she is very useful when it comes to helping with repairs & modifications.
I especially like the reinforcing spacer block that fits inside the springhangers. The lift will be useful too as on occasion tires have been rubbing on the bottom of the slides.
I wish I could answer that for you but I never saw mine until it was installed.
