I've had a wheel alignment/axle straightening job done in a truck/trailer shop on a previous trailer. That was 8 years ago & I recall the bill being near $1000.
I understand that the Correct Track system adjusts only the axle alignment. I am all but 100% sure that my axles are out by the difference between tires each side & Correct Track should correct this.
Individual wheel alignment through axle bending is another matter. Hoping all is good on that side of things.
I'll be doing the install in a boatyard so I will have access to all kinds of tools & blocks short of using the travel lift to pick up the trailer & hang it 6' off the ground.
