I wouldn't. Installed as an aftermarket item it will place more stress on your spring hangers which could cause them to break off. As an alignment it doesn't do much. It will only allow you to adjust the tracking which is how square the axles are with each other and with the frame but will only allow adjustments within its limits. It does nothing for toe adjustments or camber adjustments. A good heavy truck suspension can correct all three of these adjustments.
B.O.
