laknox
Apr 09, 2018Nomad
2012Coleman wrote:
I'm going to look at a covered storage at a private residence that was used by the prior home owner to park a class A. The current owner told me that there is enough room to pull in forward and swing around to back in. Not sure of anything else, except that it has a dirt floor.
If I decide to utilize this space, I most likely would get some 12X12 pavers for under the tires and landing gear. Are there any cons to parking in a covered space with a dirt floor?
Get some 2x8 redwood boards, cut and stack them, then screw together. Use that to roll up on. What I did with my old Komfort and it seems to have kept the worst damage from happening. Only thing I'd do different would be to cut one board about 4" longer and make that the bottom board; give myself a bit of a step. As it is, I cut an 8' board in half, then staggered the boards 2". Problem is that if you go off the opposite way you rolled up, the other end will pop up. Did that and tweaked my steps a bit.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
