donn0128
Apr 09, 2018Explorer II
I personally see no reason to put blocks under the tires. All that will happen is the cement will collect and hold moisture against the tires.
The only thing I would do would to place lots of traps everywhere. That and if you live in an area with ants, be sure to use diamatious earth or some other form of ant deterrant around everything that touches the ground.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
