Mile_High
Sep 30, 2014Explorer
Is it under the bedroom slide, extending down to the frame? IF so, that is a common problem. The flex in the frame is too much with the slide bouncing on top of the floor, and the rigid wall cracks at the weakest point. A few years ago, a saw cut and moulding was the factory answer to avoid the crack.
If that's not the area, then I'm not sure what you mean.
About Fifth Wheel Group
