ependydad's avatar
ependydad
Crazy idea- add 1/2 bath to garage area?
Ok, so here's my wild idea for the moment. Let's say there's a Toy Hauler that I like but it doesn't have a 1/2 bath. (And a 1/2 bath is on our absolute "must have" list for us.)
How crazy is it to build a 1/2 bath in the garage?
And assume that I don't mind losing garage space to it.
The idea:
Here's my wild-idea... put the black tank on the floor and then build the bathroom on top of it. There would be a step up into the bathroom. The toilet on one side and then the sink on the other. Like my current 1/2 bath, the tank would be vented with an air admittance valve under the sink and the sink itself would be have a real p-trap. Looking at random black tank offerings, you could get a 15-20 gallon tank in a variety of sizes and depths.
Dumping it:
So then the next thing is- you'd need a way to dump it. You should be able to plumb in a end of line termination valve directly close to the tank or with maybe a short stub of a 3" pipe.
If the tank is set back from the wall- you could put in a long shallow hatch (like this? might be a little long for what is needed). The trick there is watching where studs are in the wall and making sure there's an un-interrupted span for the hatch.
You could even add a black tank flush right there.
Supplying water:
I guess that's the trickiest part. You'd have to run all new PEX lines. I assue you would just T-off near an existing fixture.
  • Your clicky isn't working.
    I think running the Pex lines would be the easiest part of this project.
