- Verify that the positive is not grounded somewhere.
Disconnect battery, remove all 12 volt DC fuses from power distribution panel, disconnect from converter. Measure resistance between the positive wire and a good ground. Should show no or very high resistance. - RDalrExplorerI did that before ordering a new converter. After replacing both fuses, I connected the power supply to 110 volts. The converter was not converting power to DC.Could not get any reading on the DC side of the converter.
- You should be able to disconnect the battery, install new fuses. The converter should then have 13+ volt output.
- RDalrExplorerEnblethen.. thanks for the manual. My battery may be shorting out!
- Do you have the Manual
There is testing procedure in it. Have you tested it per the manual? - ChuckSteedExplorerHope you tried replacing the fuses first before you ordered a new converter.
Usually the two fuses you have blown will only blow when battery has been comemcted in reverse polarity.. or if someone tried to put an external charger on the battery backwards and converter was connected that would also blowmthose reverse polarity fuses - RDalrExplorerThe converter I was using is a powermax 3-55 amps. I ordered the same as a replacement. Currently, I am using my battery and a charger to recharge it.
- Something outside of the converter caused the fuses to blow.
RDalr wrote:
While you wait... have the battery checked.
My converter has blown both 30 amps fuses and it no longer converts 110 volt to 12 volt DC current. I ordered a replacement. Thank you all for your suggestions.- I would check your battery to make sure it is connected correctly.
The negative should go to the frame of the rig.
Would you post make and model of your current converter?
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
