neal10a
Jan 10, 2019Explorer
Check the circuit breaker between the converter and battery. Many have a manual CB with manual reset. However, in many trailers with a three stage converter will maintain the fridge at 13+ volts if the CB to the battery has tripped. So not knowing your trailer model or make or wiring configuration it is difficult to help you. A 3 stage converter in bulk charge will put out 14+ volts and absobtion charge will be 13.5 and float charge (fully charged ) will be 13.2v.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
