michigancougar
Feb 12, 2016Explorer
last truck had a husky slider and in a tight turn had the pavement give way under the truck causing contact between the 5er and the truck after $1000 repair when I got the new 2014 Ram I went ahead and purchased the pullrite Superglide and couldn't be happier - no more deciding if I should slide it or not - it just slides automatically on each turn. as far as height we did have to do a 6" lift on the camper because of the tall truck and the 2004 cougar. welding shop cut the axle mounts off - added 6" box tube and bracing across - also doing the same for the stabilizing jacks and going to a 4 step entry and all it great again
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
