StarTraveler's avatar
StarTraveler
Demco #6099 Dodge Prep Truck Bracket installation
Has anyone install the Demco #6099 Dodge Prep Truck Bracket in a 2016 Dodge RAM? I just purchased a 2016 RAM 3500 short bed truck with the factory 5th wheel prep option, I am trying to install the Demco bracket but am having a problem with the locking pucks. Everything lined up but I could not turn the handles to lock it in place. I removed the Washer Shim at the top of the locking pin and was able to turn one of the four locking pins. The other three still seem to not drop down far enough to provide clearance to turn the pin and engage the locking feature.
Anyone have this problem and how did you resolve it.
Thanks
  • I can't speak for the Demco system but when I installed my B & W into the factory pucks the hitch base is equipped with adjustment bolts The instructions are to loosen the bolts slightly, enough to allow the "feet" of the hitch to move ever so slightly, the base drops into place, you re-tighten those bolts and from that point on you're all set. Might there be the same thing on your set up?
    Dan
  • I'm not too familiar with the factory prep but do you have a plastic bedliner? If so, maybe trim it a little so it can sit flush?
