- mrbuck50ExplorerWell, it happened again. The crappy little micro / convection oven died again. We decided last time it would be replaced with a better quality one when it quit again. We ended up with a GE Profile from Best Buy. Caught it on sale for $539....not exactly cheap, but I hope we dont have to replace it every 10 months!! Anyway, this requires heavy modification to the surronding cabinets. I had to pull everything down and start from scratch. I managed to save the small space above the micro, but the cabinet to the right is about half of what it used to be. Wifey isnt very happy about that, but LOVES the new unit. It does not seem to put out the heat that the stock one did. She can convection bake for 60 mins and never raise the temp in the space. Now to my question......has anyone succesfully matched the stain color of the cabinets? As I said, I had to modify quite a bit and need to re-stain several pieces. I have tried in other locations to buy stain from Lowes, but nothing matches very well. Second question......does anyone know where to buy the solid surface counter top material? Wifey would like a solid surface cover for the stove instead of the metal one.
Thanks to all... - M_GO_BLUE1Explorer
eaherrmann wrote:
Off to the Hershey RV show. This is what I call tempting fate. There's always going to be something we like more than our current trailer.
Now you know better than to go to another RV show...:S - eaherrmannExplorerOff to the Hershey RV show. This is what I call tempting fate. There's always going to be something we like more than our current trailer.
- CHV_FRKExplorerWe have an 08... I do not have those hookups.
- scootskExplorer IIII guess no one knows what the rca plugs are for in the storage area.
- M_GO_BLUE1ExplorerThe only plug I know to the rear of that plug is the airbed outlet and another outlet between the fridge and J-couch...I'll check those
- CHV_FRKExplorerI can tell you that won't do anything, especially if it worked when you plugged it into an extension cord and it worked.
If you can't get to the junction, check the outlets on the same wall as the fridge but to the rear. A couple of them should also be feed from the fridge plug "upstream". Maybe where the air bed is plugged into. If those work it may just be the outlet itself. If they don't you need to work or way back to the breaker hitting the junction box and another split to the street side utility circuit as well. - M_GO_BLUE1Explorer
yogi154 wrote:
Blue, a quick check would be to plug-in the frig to an extension cord. Did you shut off the breaker and turn back on ? some times a breaker won't trip all the way to trip position. Just my 2 cents
I did plug the fridge into an extension cord and it will work on electric that way...also plugged a light into the fridge outlet and that did not work...
Have tried tripping the breaker a few times to no success....there is a 15A fuse (fridge/roof vent) I have not changed yet but that is next... - CHV_FRKExplorerNot sure on your setup... To access my junction boxes I removed the plywood around the vaccumm canister that you see when you open the exterior door to change the bag. My junction boxes were there on the floor. It's just a couple of square metal boxes.
- yogi154ExplorerBlue, a quick check would be to plug-in the frig to an extension cord. Did you shut off the breaker and turn back on ? some times a breaker won't trip all the way to trip position. Just my 2 cents
About Fifth Wheel Group
19,025 PostsLatest Activity: Sep 03, 2025
