- CHV_FRKExplorerMine is above the water heater and behind the valve panel. I think it's a shurflo, but I am not for certain.
edit....I forgot to mention that ours had gotten quieter, but it is still audible. If you lay down in our hallway you get a mini massage. ANOTHER BONUS - RLSA! With the curved hallway I'm developing scoliosis. - M_GO_BLUE1ExplorerDefinitely not a quiet one though...where exactly is it located at? I'm assuming somehere behind that access panel located close to the water heater...
- loydtExploreranybody know which model water pump our units came with?
- loydtExploreryou have to pour it real slow with something to get it to fill all the way up. if you use the gas pump, it will kick off at 3/4, as to why I though the guage was off. To get the last gallon or so in, try pouring the final bit into an old water jug (make sure there is no water left in it) and then pour it in.
- M_GO_BLUE1ExplorerAmazing what happens when you fill it all the way huh Loyd? :S :p :)
Still have to find an easier way to fill that gas tank other than using a gas can...can't get that last gallon or so into the tank...other than filling while at the gas station (um yes could you turn on both the diesel and gas pumps please? (based on the look on the attendants face)) I suppose you could use some kind of 12V pump....not sure - loydtExplorerMine handled both a/c's just fine, but then I have a 6500 where you guys have the 5500 genset. BTW, the gas guage is correct, I kept adding fuel until it got all way to top and it read full.
- cruzExplorer
M GO BLUE wrote:
Anyone try to run their 2 A/C's with the generator yet? Curious to know how the generator did...
A few weeks ago ran both A/C's, Watched the SUNS get whooped by San Antonio on the big screen, popped pop corn in the microwave ... all at the same time. Generator had absolutely no issues. Used an average of just under a gallon of gas an hour !!
CRUZ - M_GO_BLUE1ExplorerAnyone try to run their 2 A/C's with the generator yet? Curious to know how the generator did...
Where's Dave (2QAYL) been lately????? - greybouvierExplorerI washed mine last weekend and waxed with ProtectAll. Works great. Now if it would only stay clean!
- loydtExplorerThey may prep the T-stat wire now. They did not on my '05 Designer I had.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
