MFL
Jun 01, 2017Nomad II
Colo Native wrote:
It will not go in with the hub in place but if I take it off it will flow through the hole, but it doesn't fill the cavity with the bearings in place
Are you using too thick, not recommended grease? Are you raising the wheel slightly, and turning it a little as you pump grease? I needed 50 strokes of the lever before grease started to move through the front bearing, when starting with an empty hub.
Even a hand operated gun, will push the grease out at some point, even if it has to move through the seal onto the brakes.
A couple tips, put the grease gun in the sun a bit, before use. The grease flows through warm bearings better than cold.
Jerry
About Fifth Wheel Group
