Greyhound_RB's avatar
Greyhound_RB
Difference between Yamaha & Honda Inverters
Quick question about engine displacement between the newer 2200 watt inverter generators. The Yamaha says 80cc and the Honda says 121cc. The Handa has 50 % more displacement than the Yamaha. If this is true, wouldn't the Yamaha have to run at a good bit higher rpm to put out the same power. If true I cant believe they would both last the same amount of engine hours. Any thoughts?
