mdamerell
Aug 10, 2014Explorer
The pin weight is on the landing gear when not hooked to the truck. So 13,680# (which I take to be the capacity of your tires) -10,680# (actual) leaves you about 3,000# for stuff.
If you look on a 14,000# GVWR 5th wheel, it will normally have two 6,000# axles since the other 2,000 plus pounds is on the pin/landing gear.
About Fifth Wheel Group
