Aka_the_breeze's avatar
Oct 03, 2019
Disc brake pads
Looking to change the pads on my discs, been using Kodiak pads and want to change to semi metallic after much reading...
Saw some using the NAPA brand- " Made in Mexico ".. has anyone had issues with that particular pad ( UP7136M ) ?? or has anyone found that same " made in USA " .. DOES IT MATTER??
  • Aka the breeze wrote:
    OP here..
    My pads are also based off an automotive application... Just wondering if someone has found a good American Made pad that is quality.... I will check out the EBC brand..
    If you find em let us know. My first set of the NAPA pads were US Made and last Mexico. FordGuy listed pad number you can cross reference.
  • SidecarFlip wrote:
    Irregardless, EBC pads are Made in USA ad I'm not posting that because I sell them, they are.
    Not all.
  • Just put new pads on our Titan system: Napa UP7136M
    Excellent performance.
  • OP here..
  • Second Chance wrote:
    ford truck guy wrote:
    ...I am not so sure that the fact that they are made in Mexico bothers me, as long as they are quality and hold up...
    It's quite possible that the PowerStroke in your F350 was made in Chihuahua...
    Rob
    I guess its good that I noted that as long as it is quality and holds up that it is not an issue . .
  • Housted wrote:
    My titan system uses MKD289 pads available everywhere.
    The reason is that they are the same as Beretta Cavalier Corsica Sunbird Skylark Cutlass Calais Grand Am Century Skyhawk Celebrity Cutlass Ciera 6000 Cimarron Firenza 6000 Somerset Calais 6000
    Makes it easy to get replacements.
    Housted
    Same as my Kodiak system.. Buick Centry 1983 - 1995- fronts among others available..
  • My titan system uses MKD289 pads available everywhere.
    Housted
  • Irregardless, EBC pads are Made in USA ad I'm not posting that because I sell them, they are.
    Rob
  • I use NAPA'a Best UP-7136M on my Kodiak system with Morryde IS 8k..
    I saw a big difference in stopping power when I swapped out from my stock Kodiak ceramic pads to the NAPA semi metallic pads...
